FieldPoint Family
Fieldpoint LabWindows CVI
I have a compact field point cFP-2120. The field point is connected to the network and is approachable from NI-MAX (version 15.3). All the fieldpoint items are approachable from the Data Neighborhood and the settings are saved in the myfieldpoint.iak. I can correctly read and set all the settings in the data neighborhood.
I want to control the fieldpoint from a labwindows CVI c program (Labwindows CVI 2015). As a first test I run the Fieldpoint example project (installed by fieldpoint installer): FRAI Read Cache Example. The code compiles fine but the program gets an error on the following line, trying to connect to the fieldpoint:
status = FP_Open (NULL, &FP_handle));
I also tested
status = FP_Open ("myfieldpoint.iak", &FP_handle));
with
static IAHandle FP_handle;
IAStatus status = IA_SUCCESS;
I get the status: status = 33922; If I now ask for the error message: FP_ErrorMsg (FP_handle, status, message); I do not get an empty error message. Probably since FP_handle = 0 ?
Can you help ?
Message 1 of 1
(4,032 Views)
