FieldPoint Family
Fieldpoint Read - Significant Figures
I would like to know if it is possible to adjust the number of significant figures when reading an analog channel from compact fieldpoint.  ie.  channel reads  0.003973554654  I want to read only 0.00397
(7,175 Views)
Where do you send this data value to?  If you send it to an indicator, then you can set the properties of the indicator to however many significant figures you want.
(7,167 Views)
I'm performing some computations on the value, then logging it to a text file.
(7,162 Views)
Use the format into String function from the String pallette.
For the format specifier use   %_3f  where the 3 represents 3 significant digits.
(7,158 Views)
Thanks!
(7,156 Views)
