FieldPoint Family
Fieldpoint firmware revision - programmatically
Does anyone know how to obtain the firmware revision # from Fieldpoint network modules (specifically: cFP-2020). I know how to do this through FP explorer or MAX (LV7), but I need to do this programmatically.
David Moerman
Advanced Measurements Inc
(3,558 Views)
Greetings David,
You can use datasocket to programmatically gain the version number of the network module. The URL that you will use is:
lookout:\\xxx.xxx.xxx.xxx\FP\Control\Version
where xxx.xxx.xxx.xxx is the IP address of your module. You can find this URL also by creating a front panel datasocket connection and browsing to your network module.
Hope this helps. Have a good day.
Patrick Robinson
Applications Engineering
(3,558 Views)
