FieldPoint Family
Historical Logging Queue Overflow
Generating an error "Historical Logging Queue Overflow" Error Code -1967390689. At this time my data logger turns off, no longer allowing me to log data. My input and output queues sizes are roughly 20,000 and my buffer size is 30,000. Possible errors? My database is not very big, I have only run this file for a little over 24hrs. I have not had time to accumulate much data.
(3,450 Views)
What are the deadband settings that you are using on the objects you are logging? It appears that the values may be changing so rapidly, that an overflow is occurring before the data can actually be written to the database. You may want to check out the following KnowledgeBase, as it may have some useful information.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/862567530005f09e862567c700746a65?OpenDocument
Hope this helps,
Patrick R.
(3,450 Views)
