FieldPoint Family
How can I change FieldPoint scaling value from Labview not Max?
I am searching for a solution to change FieldPoint Scaling Value Whitout using Max.
Thanks for your Answers.
(3,928 Views)
Snif, nobody ansered me.
Does this mean there is no way to change the FieldPoint scaling values, no ActiveX no DataSocket Command?
The only way to change the scaling value are manually from Max. I don't belive it.
I have found the FP-1000/1001 Programmer Reference Manual but it doesn't say anything about the scaling value
and I'm using an FP-1601.
Thanks for your anser.
(3,905 Views)
I think if you surf to the National Instruments/Labview x.x/vi.lib/Fieldpoint/Configuration folder, you'll find what you need in those LLBs, but I've never tried it.
Mike
(3,889 Views)
Thank you for you answer, but i already looked there and there are 3 usable VI for configuration : range deadband and attribute configuration.
Range and deadband have nothing to do with the scaling value.
Here is the list of the configurable attibute:
Input Filter\Noise Rejection, Thermocouple Type, CJC Source, RTD type, Terminal Count, Terminal Count (MSB), Count Source,
Gate Source, Read Reset Mode, Output Source, Output Mode, Period, Period (MSB), Pulse Mode, On Time, On Time (MSB),
Off Time, Off Time (MSB), Resolution, Reset Mode, Excitation Voltage, Half Bridge Completion, Measurement Mode.
No sign of scaling value attribute, snif.
(3,885 Views)
