FieldPoint Family
How can I retain the local user name when using imported network tags?
I am using network tags that have been imported from a remote DSC module 6.1 application. I would like to retain the remote user in the tag records instead of whoever is logged in locally. Is this possible?
(4,691 Views)
This question should be posted in the LabVIEW Datalogging and Supervisory Control forum. This forum is for FieldPoint related issues and questions.
Aaron
LabVIEW Champion, CLA, CPI
(4,691 Views)
I am not sure I totally understand your question so would it be possible for you to elaborate a little bit more on that topic.
Did you just import the tag and made changes locally or are you actually connected remotely to the process on the remote machine?
Let me know what the situation is:
Cyril Bouton
Applications Engineer-Industrial Automation
www.ni.com/support
Cyril Bouton
Active LabVIEW Developper
(4,691 Views)
I am connected to the remote process through network tags. Data is being logged locally at the process and on another workstation where the network tags are configured. I need to record the original user of the remote process for tracebility. This works fine on the local system, but the person logged into the workstaion using the network tags gets recorded in that database. I just thought there may be a way to retain the original user id.
(4,691 Views)
Unfortunately there is no pre defined option for that, but one thing you could do, if you need to record the original user of the remote process for tracebility,is to use the security VI's on System>>Security Palette of the DSC functions to create a login programmatically on the workstation where the tags are configured and send the value of the user name to a string tag that you would retrieve on the other workstation.
Hope that helps.
Cyril Bouton
www.ni.com/support"
Cyril Bouton
(4,691 Views)
Thanks, I think I will end up logging to a remote database instead of locally.
(4,691 Views)
