FieldPoint Family
How do I add signals from different modules to the same waveform chart?
When using build array to connect signals from different FP modules to the same waveform chart, the array type is not the same as if all the signals come from one Read Array. Only one digital indicator on the chart displays with the build array method. Why
(3,277 Views)
Hi gencell,
There are two ways to plot multiple plots on a Waveform Chart, a 2D array and a cluster of doubles or integers. I would suggest that you use a Bundle to create a cluster.
This information is in the Context Help of the Waveform Chart terminal (from the Block Diagram).
Chad Evans
(3,277 Views)
