FieldPoint Family
How do I programatically set the date and time of my FP-2000 in LabVIEW RT?
I checked out the following knowledgebase document which has a tool for setting the system time, but I also need to set the date:
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/37175dbc3696a1ac86256a850051097d?OpenDocument
How can I do this?
-Jim
(4,122 Views)
Jim,
As you noted, the example (above) does not currently support changing the date. I have requested that the ability be added to the example/tool, but I do not currently have a good estimate as to when the upgraded tool will be available.
Aaron
LabVIEW Champion, CLA, CPI
(4,122 Views)
Aaron,
I found functions in kernel32.dll called SetSystemTime and GetSystemTime. These use a cluster similar to that used by "Date/Time To Seconds" and "Seconds To Date/Time" I tried them out on my FP2000 and they worked just fine.
-Jim Kring
(4,122 Views)
