FieldPoint Family
How do I programmatically determine if fieldpoint is powered up?
I am using two cFP-1808s and programming in VS 2005 C#. Is there any way to determine in code wether the cFP-1808s are powered on? I am using datasockets to read data and have discovered that if you connect to a datasourse that does not exist, the server crates the data source with a default value of 0. This causes a problem when I try to disconnect, the programs just hangs after the datasocket.disconnect() command.
Willy
(7,525 Views)
Really there is no way to know other than getting a timeout error when you try to communicate with it.
Chris Bakker
SET Americas
CEO
(7,441 Views)
Then why is it allowed to connect to a datasource that does not exsist?
Willy
(7,423 Views)
Even datasocket should give you an error message, if an address is not correct, because the module is not there or its a different module, or network is down or the 180x is not powered up correctly.
So checking the status comming back  from your datasocket function should fix this issue.
DirkW
(7,405 Views)
Unfortunately, this is not the case. The DataSocket.Connect returns void and only throws the System.ObjectDisposedException. Furthermore, the Measurement Studio help file states ". . . if you connect to a data sourse that does not exist, the server creates the data source with a default value of 0."
(7,395 Views)
You are correct Willy, an offline controller doesn't give an error.  You can try pinging the device, either by using a generic TCP write function or using RT Ping Controllers.VI, which will find all NI controllers on your subnet and return info about them in a cluster of string arrays.  If it is not found by this VI, it is not powered on.
Chris Bakker
SET Americas
CEO
(7,387 Views)
I found the RT System Replication VIs very useful in detecting whether a RT target is online. Check the article below.
http://zone.ni.com/devzone/cda/tut/p/id/3937
Volker
(7,275 Views)
