FieldPoint Family
How to calibrate FP-TC-120
Now, I am using FP-TC-120 and FP1000 to read temperature using the labview. However, i don't know how to change the value recieve from the FP-TC-120 to a precise temperature.
Do I need a amplifier or low-pass filtering board.
Please give me some advices.
Phong
(6,087 Views)
Hi nnphong,
I’m not sure what you mean by ‘’change the value received to a precise temperature’’. Do you mean that you are reading the signal with a lot of noise? Or that you are not seeing temperature data? Do you have the module configured for your type of thermocouple?
(6,073 Views)
Hi amezam,
Thanks for your reply. I can see the temperature data, but it is so fluctuated. And, i realized that there is a problem with my TC. Now, i am using a new TC and it's oke.
Many thanks,
Phong
(6,019 Views)
