FieldPoint Family
How to change the period of cFP-PWM-520 in labview program
lovexf,
Suggest you open up the Configure Attribute.vi and use Highlight Execution to determine exactly where the error is occuring.  My guess is that the error occurs in a sub vi named DS Sync Write (Word).vi.  Begining to suspect this is a Data Socket problem.  You could try writing your own vi that directly uses the datasocket functions.  This document goes into advanced data socket a bit more and some things that would keep it from working.  http://zone.ni.com/devzone/cda/tut/p/id/4499#toc1
What field point controller are you using?
Message 11 of 15
(4,296 Views)
lovexf,
I may have figured this out.  As I said before, the Configure Attribute.vi is using a logos datasocket  to modify the settings on the cFP.  The vi is generating a URL with back slashes.  I'm pretty sure that a logos datasocket needs a URL with forward slashes.  I found this document.  http://digital.ni.com/public.nsf/allkb/B0C5F514A850BF8F86256DAB0047BB98  I've got a call into NI to verify that this is indeed a bug in the FP library.
Message 12 of 15
(4,291 Views)
Wayne.C
     It’s very kind of you to do this for me, now it  perfectly done . Communicate with you, I leaned more about the FP.Thank you ,my teacher~~
Message 13 of 15
(4,262 Views)
lovexf,
Glad to hear that it is working.  Can you tell me which model of cFP you are using and what version of LV you have loaded?
Message 14 of 15
(4,256 Views)
As you see,the image that I uploaded last time, it is cFP2020,with labview8.6 version
Message 15 of 15
(4,252 Views)
