FieldPoint Family
How to create remote monitor and control webpages using cFP2220
Hi all,
I'm fresh user using compact field point. I would like to make cfp2220 as a web server, so other PCs can using IE to monitor and control through web browser.
Moreover, does the webpages support security? and how to setup?
Robert :smileywink:
(6,324 Views)
Hi Robert,
You can use LabVIEW Web Services to set up a system like you describe, and there is also information available on how to secure your Web services.
I hope this is helpful.
Stephen S.
Applications Engineering
(6,301 Views)
