FieldPoint Family
How to generate a synchronized train of pulses with FP-PG
I need to generate a sequence of pulses to drive a Step Motor using the FP-PG-522. The sequence its very simple but it involves using the 8 channels of the FP Module. My question is how to tell with precise timing when each of these pulses to begin in order to create the pattern of pulses needed to drive the motor.
(3,431 Views)
The FP-PG-522 is not the way to go in order to accomplish what you need, you have to investigate how to generate this pattern using a high speed DIO board instead, I am pretty sure this is easily accomplished with one of them, however this is not possible with the FP-PG-522.
Andre Oliveira
(3,431 Views)
Thank you Andre!!
(3,431 Views)
