06-13-2007 09:28 AM
06-13-2007 09:39 PM - edited 06-13-2007 09:39 PM
Message Edited by Ravens Fan on 06-13-2007 10:42 PM
06-14-2007 01:34 AM
I am using a field point with up to 3 moduls with each having 8 channels. Now I do not know with what to connect the case structure and how to extract the values of the 1D array. I certainly expect that this is no problem for an experienced programmer. But I just started with labview and need your help with this one.
Daniel
06-14-2007 06:58 AM
Hello Daniel,
I implemented a little VI for you. Look at the attachement. I also added some colors to the table so you directly which are connected and which not.
Kind regards,
06-14-2007 08:39 AM
Hi Julien,
That helped me alot. I managed in the meanwhile to build myself a solution aswell, but it your solution looks better to me
The implementation with the colour is a great feature.
Thanks you alot.
Greets
Daniel
06-14-2007 09:04 AM
No problem Daniel. I'm glad to make you happy ![]()
