FieldPoint Family
How to read the raw (volt) value of a AI scaled Fieldpoint Channel in Labiew?
Is there a labview native vi to read the Raw value of a pre-scaled (Max) fieldpoint channel?  I can't seem to find anything in the advanced palette either...
Thanks...
(6,030 Views)
Howdy!
I am confused since the subject and your question seem conflicting. However, the process of reading a scale and none scale FieldPoint channel in LabVIEW is basically the same. You will create a scaled channel in MAX and then use the FieldPoint Read and Write VIs and select the appropriate FieldPoint I/O Tag. See KnowledgeBase 2HFB8PQ7 How do I Read, Write, or Scale Multiple Channels on a Fieldpoint Module in La... for more information
Joshua B.
(6,005 Views)
