FieldPoint Family
How to use multiple channels to sample one signal
I would like to use all channels on an AI-110 to sample the same signal in order to increase my sampling rate.  (I have spare channels, not spare $$.)  In hardware the channels are read sequentially so in theory I should be able to do this, but I'm having trouble reconstituting the signal.  If I use FP Reads the timestamps seem to indicate the time of the read, not the time of the A/D conversion, so I can't tell which sample was taken last.  FP-Advise on change seems ill-suited as well since consecutive samples may be the same on a certain channel, but the signal may have varied in the mean time on the other channels.
Any ideas how this might be done otherwise?  The VI will run embedded on a cFP-2020 controller with LabViewRT v. 6.1.1.
Anton
(3,494 Views)
Anton,
I understand what you are trying to do and do not think it can be done with a single module.  The timestamp on the FP-Read is all about when the vi returned the data and not when the A/D conversion occured.  I just don't think that the A/D converter can keep track of the conversion time.
If you had multiple AI-110 modules, you could in theory connect your signal to individual channels on multiple modules and then sequence through the modules.  The problem here would be the ground loops.
(3,483 Views)
