FieldPoint Family
How to wire the discrete input 1 & 2 for CFP2020? What is the specs (voltage limitation, etc)?
Can I put an external power supply (5V) with a dry relay contact into the Discrete input? or do I need anything else such as resister? Will this "fry" the discrete input?
(3,015 Views)
Thank you for contacting Nagtional Instruments.
If you know that voltage that you are connecting will not exceed +5V, then there is no need to include a resistor. Make sure that the ground of your +5V source is referenced to the same ground as the cFP-2020 power supply. You can include a resistor if you are afraid a short may occur causing a large current spike, but again it is not required.
Bill B.
(3,015 Views)
