FieldPoint Family
I carried out a reset since status flickers
At the time of the installation of my chain of module field point (FP2010, FP-AI-111, FP-AO-200, FP-TC-120) I tried to make communicate my modules with my computer thanks to a standard interface Ethernet.
Unfortunately only the central module (FP2010) was detected, of this fact I carried out, in accordance with the note of use, a reset of my installation and since the status flickers continuously. What do I have to make to cure this disfonctionnement? Thank you in advance.
Bouzon Ophélie
(3,092 Views)
Try to disconnect the controller FP-2010 from all others FP modules (do this without power supply).
Move the RESET switch on the front of the module to the ON position. Power up the FP-2010 --> the red STATUS LED must start flashing. When it flashes, the FP controller is in reset mode.
Then, Move the RESET switch back to the OFF position. Connect all the FP modules again. Connect your crossover ethernet cable and power the FP controller up again.
Hope it will help you...
Regards
David D.
AE - NI France
(3,083 Views)
