FieldPoint Family
I need check the range channel in cFp-2120 in file Configuration Programmble
how check the range channel cFP-2120 Programmble to check if the range change or not
(3,284 Views)
The range of the channels is not going to change after you configure the task. However, you can programmatically set the range with the Configure Range.VI. This is located in Measurement I/O >> FieldPoint >> Advanced >> Ethernet Advanced. I hope that you find this information helpful.
Hal L.
(3,270 Views)
