FieldPoint Family
I want to install a Matheson MFC as an output device to control differential pressure, can anyone help?
I am trying to build a control system that controls a flow based on a differential pressure. I have the pressure transducer wired to an AI and I'm trying to figure out how to configure the I/O for the MFC.
(3,132 Views)
Please provide more information on the make/model of the Matheson MFC that you are using. Some specific questions that would enable people to better help you are:
How are you trying to talk to the MFC? Does the MFC have Analog Input channels that you will use a FieldPoint Analog Output module to control or does it have its own communication interface? Provide a link to the specs/user manual if it is available on the web.
What programming environment are you using?
Aaron
LabVIEW Champion, CLA, CPI
(3,132 Views)
