FieldPoint Family
In Executable FP Write works, but FP Read gives error 32812 (tag not found)
I am trying to get an executable version of my code to run on another machine and I have been slowly working the bugs out. The executable runs well on the machine on which it was developed, but I get an error when I try to run it on another computer.
I was getting error 32812 (specified tag name was not found) when I tried to write to any FieldPoint devices. Then I updated the Fieldpoint drivers to version 4.1 and it started working until I tried to read from a FieldPoint device. Now I get the same error at FP Read instead of FP Write.
Any help would be greatly appreciated.
Thank you,
David R. Asher
Certified LabVIEW Architect since 2007
(3,813 Views)
I have narrowed the problem down to the FP-QUAD-510 module. The problem seems to be that when I try to open the IAK file on the computer that doesn't have LabVIEW installed on it the position 0 to 3 channels do not show up under the encoder device in the data neighborhood. Both computers have the same version of Measurement & Automation Explorer, as well as the same version FieldPoint Drivers.
I can't figure out why the Position channels won't show up.
(3,811 Views)
There are some great KnowledgeBase entries that deal with this issue. You can access them by follwing the links below.
http://digital.ni.com/public.nsf/websearch/BAE9008FD3505985C1256BFF0065B047?OpenDocument
http://digital.ni.com/public.nsf/websearch/D12EC14A601335E486256F470072E7FB?OpenDocument
(3,792 Views)
