FieldPoint Family
Incorrect timestamp to string conversions?
Why does this code give different times when the UTC format? input changes?  The FieldPoint controller
timezone is set to UTC and compensate for DST is disabled.  I would expect the two conversions to give the
same result in this case but they don't.  RT 8.5.1.  The timestamps of readings in MAX are correct and the
string formatted with UTC format? True is correct.
Thanks.
Matt
Message 1 of 8
(9,597 Views)
Hi Matt,
I have been able to reproduce the behavior that you are seeing in LabVIEW 8.6.1 as well.  I'm going to have to look into this a little further to determine what is going on.
Justin Parker
Product Support Engineer
Message 2 of 8
(9,572 Views)
Thanks Justin.  This started as a query from a customer running RT 6.1, so it looks like
we have confirmation for 6.1, 8.5.1 and 8.6.1.
Matt
Message 3 of 8
(9,564 Views)
Hi Matt,
I checked into this and R&D is aware of the issue.  It seems to affect the PharLap FielPoints but not the VXworks FieldPoints.  You should get the correct information by wiring a True to the UTC terminal.  This is supposed to be fixed in a future release, but I can't give any specifics.
Is this causing any issues, or were you just curious why this behavior existed?
Justin Parker
Message 4 of 8
(9,545 Views)
We're still seeing this in LabVIEW 2012.
But it only appears to affect dates in BST, as soon as you get back into GMT this '-1' day error goes away
Message 5 of 8
(8,451 Views)
Hi Kevin,
I'm no longer on the RT support team, but the CAR was 41190 and was fixed.  But looking at the VI I see it has an event structure, making me think that its not being run on an RT target.
Are you seeing this on an 21xx FP in LV 2012?
Justin Parker
Message 6 of 8
(8,445 Views)
Hi Justin,
No - I realised as I posted this, that it wasn't related to LabVIEW RT - but my original search only found this thread...
I've since found http://forums.ni.com/t5/LabVIEW/Time-Conversion-from-Local-to-UTC-Help-Daylight-Savings-Problem/td-p...
It appears to be a standard LabVIEW 2012 'feature' - you can move my post to the above thread if you wish
Cheers
Kev
Message 7 of 8
(8,415 Views)
No worries, I just wanted to make sure I understood your question (and if I needed to reopen a CAR).
I happy to hear you found your answer.
Justin Parker
Message 8 of 8
(8,407 Views)
