01-23-2008 01:38 PM
01-24-2008
12:25 PM
- last edited on
05-23-2025
04:02 PM
by
Content Cleaner
Once you have configured your FieldPoint hardware in Measurement and Automation Explorer (MAX), you can use an .IAK file to save the configuration. Opening an .IAK file in MAX will recover all of the FieldPoint configuration properties that were previously saved.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kGgPSAU&l=en-US
One important note is that the same version of the FieldPoint driver should be installed on both host PCs that you will be accessing your FieldPoint hardware from. You can check this version in MAX by navigating to My Systems, expanding the Software tab and choosing FieldPoint.
