FieldPoint Family
Intermittent fieldpoint error with exe
Hello everyone,
I have created an executable program which works correctly for the most part.
I have attached a bmp of the error im receiving. The problem is though, that I dont get this error frequently (and it only happens when I load the program). Does anyone have any indication as to what causes this?
One thing further, the error is generated on the host pc code and not from my FieldPoint code.
(3,338 Views)
Hello DavidT
I have never seen that type of error, but I would like to know more about what other programs your LabVIEW application interfaces with and what you mean exactely when you say that the error is generated on the host PC and not from the FieldPoint code.
Serges Lemo
Application Engineer
(3,338 Views)
Hello Serges,
Im running an FP-2010 controller with several TB-10 bases. Im communicating between the controller and my Controller PC via ethernet.
I have a DAQ exe program operating on my FP-2010 and a HMI exe on the controller PC.
Sometimes (and only sometimes), when I launch the HMI exe, I will receive the error I attached previously.
Im operating the HMI code with the following system:
LV 7.1
LV Real Time 7.1
FieldPoint 4.1
Windows XP
thanks
(3,338 Views)
