FieldPoint Family
Is it possible to work with Fieldpoint in combiantion with Delphi
I want to use Fielpoint modules and program them with
OPC and Delphi. Is this possible, or is it better to use LW-CVI.
(3,342 Views)
If you have an OPC Client for Delphi, it should be fairly easy. If you are trying to develop an OPC Client for Delphi, then it will probably be quite a bit more difficult. I would recommend taking a look at National Instruments Application Note 139: Developing an OPC Client Application Using Visual Basic. The App Note centers around using DataSockets as a Visual Basic OPC Client and uses the FieldPoint OPC Server for it's examples. Whereas you will probably not be using DataSockets as your OPC Client, the App Note provides some good information on the FieldPoint OPC Server naming structures. It can be found at:
http://zone.ni.com/devzone/conceptd.nsf/webmain/87D5C15CAFB2654A86256874005C280C/$File/AN139.pdf
Aaron
LabVIEW Champion, CLA, CPI
(3,342 Views)
