FieldPoint Family
LV RT 6.1 executable on 6.1.1, 6.1.3 firmware?
If I create a startup.exe executable on a cFP network module that has 6.1.3 firmware
will it run on a module with 6.1.1 firmware and vice-versa? Any specific issues to
watch for? Thanks.
Matt
(3,591 Views)
Hello Matt,
The startup.exe that you create in a module that has 6.1.3 firmware will run on a module with 6.1.1 firmware and vice versa, however this is specific to these two versions. This is not true with other versions though. A LV RT 7.1 app needs the LV RT image 7.1, 7.0 needs 7.0 etc. Hope this helps.
Ayman K
(3,571 Views)
Thanks for the info. We've tested both combinations successfully but wanted
to make sure there wasn't something we were missing.
Matt
(3,565 Views)
