FieldPoint Family
LabView 5.0 and FieldPoint 3.0.2 compatability
When I installed FieldPoint 3.0.2 it is supposed to appear several FP subpalettes. I can see only three of them FP Open, FP Close and FP GetConfig the rest of them have a ? sign and does not work. How I can create an application using just three of this subpalletes(in a LabView 7.0 all of them were active).
(3,611 Views)
I'm also not quite sure if Labview 5 is compatable with Fieldpoint 3.0.2, but you can find the rest of the FP Vi in the Labview VI library.
(3,611 Views)
The key here is that all of them are showing up in LabVIEW 7.0. FieldPoint Explorer only installs one set of FieldPoint VI's, although it is possible to run custom installs in order to provide support for different LabVIEW versions (by default only the most recent installation is supported). Since you are still seeing the VI's, albeit with some of them having question marks, then what has most likely happened is that you have saved several of the FieldPoint VI's into LabVIEW 7 which is why LabVIEW 5 can not recognize them. If you have another machine that has LabVIEW 5 on it, you probably want to copy the ..\vi.lib\fieldpoint folder from that machine to the vi.lib\fieldpoint folder of the LabVIEW 5 directory.
Aaron
LabVIEW Champion, CLA, CPI
(3,611 Views)
Thanks a lot Aaron G. I will try custom install several days later. And we will see.
(3,610 Views)
