FieldPoint Family
Labview with cfp -DO- 403
Hi
I have two small programs to test cfp - DO - 403 module in LabView.
The first programing,I get it from exmaple from NI. It work ok with this module.
The second programming, I create it with DO share, but i does not work, I don't see the error.
Please download and fix it help me.
Nguyen Van Hung
Message 1 of 8
(7,377 Views)
I have the same issues with cfp - AO- 200
Please support me to fix it
Nguyen Van Hung
Message 2 of 8
(7,375 Views)
Build an array of fieldpoint IO references.  Put the Fieldpoint write into a For Loop.  Auto index on the fieldpoint IO array and your data array to write a value to each IO point in turn.
Message 3 of 8
(7,372 Views)
Hi Raven,
I work ok with Digital ouput but not ok with Analog output as your guide.
Nguyen Van Hung
Message 4 of 8
(7,355 Views)
It should work equally well with both.
Post your code.
Message 5 of 8
(7,352 Views)
Here is my code.
Message 6 of 8
(7,350 Views)
I have never used the "All" channel, at least not for writing values out.  So  I don't know if there are any gotchas with that.
One thing I do notice is that for your first program, you are writing out an array of 8 elements.  But for the 2nd program, you are only writing out an array of 3 elements although it is an 8 channel device.  (Put a probe or indicator on that error wire to see if it says anything).
My suggestion was to create an array of the Fieldpoint I/O points and iterate through them in a loop.
Message 7 of 8
(7,340 Views)
Hi Ravens,
This is good method.
Thanks for your support.
Best Regards,
Nguyen Van Hung
Message 8 of 8
(7,333 Views)
