FieldPoint Family
Low Frequency Measurements using counter timers
Hi Russell,
I should have clarified more about the output pulse train. The FP-500 has 4 configurable counter outputs in addition to the counter inputs. I would like you to try outputting pulses on one of the counter output channels and wire that signal directly to the gate input. I believe that if you do this, you will be able to see consistent data.
Hal L.
Message 11 of 12
(1,236 Views)
Hal,
Thank you for all your help. I discovered why the frequency measurement wasn't working.
I needed to connect an external power supply to V and C on the CB-1 terminal block for the CTR-500.
You had a mentioned that I should make sure the module was powered, but I didn't know that I needed to connect the V and C to an external power supply.
It is all working now.
Thank you again,
Russell
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
Message 12 of 12
(1,235 Views)
