FieldPoint Family
MAX error CmxExecutionThreadPool::DoWorkNonUI
Error occurs at MAX startup with CmxExecutionThreadPool::DoWorkNonUI.  Benign?   What problems will I experience?
Message 1 of 8
(15,057 Views)
Would you mind posting some more information about your system including:
O/S:
version of Measurement and Automation Explorer:
NI FieldPoint driver:
FieldPoint hardware:
Patricia B.
Message 2 of 8
(15,048 Views)
I have experienced the same error!
O/S: winxp sp3
version of Measurement and Automation Explorer: 4.7.7f0
NI FieldPoint driver: no FieldPoint driver used.
FieldPoint hardware: no FieldPoint hardware used.
I have installed NiDaqmx device driver 9.2.3, nidaqmx max configuration 9.2.3, nipal 2.6.3, ni system configuration 1.1.3, ni pxi platform 2.5.6, labview run times 8.2.1, 8.6.1, 2009 sp1, 2010 sp1, measurement studio for vs2005 (dot net common 9.0.20.362)
Can you help us on that?
due to this error, I'm unable to view the daqmx devices. no daqmx (usb-6009), and no serial ports.
Thanks!!
Message 3 of 8
(14,872 Views)
Hey Tobogan,
To fix this issue I would start by trying to install the Daqmx 9.4 drivers from www.ni.com/drivers.  This issue seems to be linked to a particular DLL that did not install correctly with Measurement and Automation Explorer(MAX) so reinstalling MAX usually fixes the issue.  The new version of the Daqmx driver is compatable with all the LabVIEW run time versions you have installed except for 8.2.1.  This means you would not be able to use any LabVIEW programs developed for LabVIEW 8.2 on your machine.  Please post back with any additional questions.
Kevin Fort
Principal Software Engineer
NI
Message 4 of 8
(14,862 Views)
Running a LV 2010. With NI-RIO 3.5.1, the only compatible version if I'm not wrong.
When opening MAX I get the error message:
Context where exception was caught:
Func: CmxExecutionThreadPool::DoWorkNonUI Args: job=04FF4908
Further continuing with opening MAX , to add software to the rio, max says problems retrieving settings for the target, a NI cRIO 9075.
Any fix`?
9075 not compatible with LV2010?
Message 5 of 8
(13,657 Views)
Hello josens,
The cRIO-9075 was first supported in LabVIEW 2010 SP1 with NI-RIO 3.6.1 (You can see required versions here). If possible, install SP1 and get a newer version of RIO and you should be fine.
Ryan
Ryan P.
CLA
Message 6 of 8
(13,612 Views)
I recently tried to reinstall Labview 2010 on my computer. Previously it used to work but know MAX seems to have some issues : when starting MAX we get this error MAX error CmxExecutionThreadPool::DoWorkNonUI.
We tried to reinstall several times Labview but this error persists. Any idea ? Thanks a lot !
Message 7 of 8
(10,542 Views)
it's a while ago ...  I newer really got a god exact solution or reason for this error. There were several issues for me with combinding new and old rios.
I think the peroblem was related to driverissues. The new Rio was not compatible with the MAX version etc.  My solution in the end was to upgrade to a newer SW.
Message 8 of 8
(10,518 Views)
