FieldPoint Family
Maximum useable memory on cFP-2120
I'm currently running the cRIO-9004 with the cFP-2120.  I am only able to take 233mB of data before it stops recording.  It currently has a 1Gb CF card installed in it, and I'm wondering if the reason has to do with the cFP not recognizing the size of the card correctly.  The manual states that it will use cards up to 512mB in size...
I don't have any 512 cards handy, or I'd try it myself.  Any input would be appreciated, as I'm supposed to be using this in the field first thing Monday morning...
TIA
Dan
(3,309 Views)
Just wanted you to make sure that you're accessing the "D" drive, and not the "C" -- the latter is the built-in non-volatile memory.  I am pretty sure you are using D, but thought I should mention anyway.
-Khalid
(3,306 Views)
Yes, I'm accessing the d:/ drive.  After reading the manual, it appears that the cFP-2120 doesn't recognize anything larger than 512mB.  I'm currently testing with 512 card now, and should know whether or not it works properly in about an hour and a half...
Dan
(3,299 Views)
