FieldPoint Family
Measurement & Automation Explorer Bug report
Minor channel naming bug in M&AE 3.1.0.3021
In Data Neighborhood, modules FP-PG-522 and FP-CTR-502.
I tried to rename "Pulses Remaining x" to "Pulses remaining x" and "Count Input x" to "Count input x".
I got error "The name you entered is already defined. Enter a different name."
I should be able to change CAPS to small letters straight, right?
I can cheat to make it work, but that requires extra steps and it is annoying. Is there a fix for this already?
Please let me know.
(3,326 Views)
Karik,
Thanks for reporting this issue. There is currently no fix available. However, I am sure you already know the workaround. Instead of changing it directly, change it to something else (i.e. "ount Input x"), then change it to "Count input x".
Ames
(3,326 Views)
Thank you for your quick response.
Yes, that is the way to go around this problem.
I just wanted you to know about this, so we get it fixed one day.
Yours Kari
(3,326 Views)
