FieldPoint Family
Measuring Low Frequencies with LabVIEW and FieldPoint Using [c]FP-CTR-500/502
I am trying to use this example in a LabView 8.0 and a Field Point FP-CTR-502 module but without any sensor I get frequency and period values.
Is that possible to use this example with LabView 8.0 or not?
I am trying to use an anemometer Campbel Scientific A100R.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3ED7556A4E034080020E74861&p_node=174404&p_source=External
Message 1 of 11
(6,746 Views)
 What frequency do you obtain? it could be a noise.
If you connect a referenced signal, do you have these values?
Message Edité par ManuelR le 07-06-2006 04:49 AM
Manuel R
AE dans une autre vie
Message 2 of 11
(6,691 Views)
No... that is not noise. Even when I shortcut direct in the FP terminals I get random values in the frequency. I made the configuration for FP several times to confirm if there were something wrong but nothing works
Message 3 of 11
(6,682 Views)
Sounds like it could be a floating common/ground loop problem. Are all you negatives connected to the same ground point (including the power supply common)?
Steve
Message 4 of 11
(6,679 Views)
I am sure this is not an electrical problem. Even in the laboratory the displayed data are wrong. We had this anemometer pluged in a weather station an its is working well. Did you tested this program too?
Message 5 of 11
(6,676 Views)
Did you tried with Measurement and Automation Explorer?
How do you connect the anemometer to your FP? differential mode? RSE? NRSE?
Manuel R
Message 6 of 11
(6,656 Views)
I realy dont know... what does it means... is supposed to know all this to connect a simple anemometer?
The anemometer acts like a little switch, switching on and off for each revolution.
Message 7 of 11
(6,651 Views)
You can launch MAX from start\programs\National Instruments\Measurement & automation.
Concerning source signal wiring, you can have a look to the following link : https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
Hope this helps,
Manuel R
Message 8 of 11
(6,561 Views)
Is your problem solved?
Do you need more help?
Manuel R
Message 9 of 11
(6,495 Views)
No, my problem is not solved yet... Smiley Sad
Message 10 of 11
(6,473 Views)
