FieldPoint Family
More than two FP-TB-3 with FP-TC-120
I want to use 4 FP-TB-3 with FP-TC-120 and one FP-1000. Then I somehow need to wire power between the FP-TC-120 modules. The FP-TB-3 has only one power terminal "C" in each end of module, unlike the FP-TB-1 which has two terminals "C" and "V". What should I do?
(3,143 Views)
Is there a reason that you are trying to place a power supply on the FP-TC-120? The TC-120 does not require power to be supplied to its V and C terminals to operate. Through the backplane, the TC-120 will get the power necessary to operate.
I hope this helps,
Mike
(3,143 Views)
