My FP2000 has stopped booting. When I turn on the power supply, the Power LED turns on, and nothing else. Status and ABCD should light while the OS loads but don't. I've tried the reset procedure from the manual (flip reset switch, then power up). The Status LED is supposed to turn on but doesn't. As far as I can tell, this thing seems dead! Is there anything else I can try?
Some background. The unit was working fine about 2 weeks ago. I changed its IP address to a new network where it would be permanently installed and lost communication with it as expected. I powered everything down and moved it to another building. It sat there while other parts of the project were assembled and when I was
finally called in to turn it on...nothing. Any help is appreciated.
