FieldPoint Family
My Fieldpoint FP-TC-120 "forgets" that I want it to take temperature in C and reverts back to voltage measurements (default)when it looses power.
Is there a way to fix this so I don't have to reconfigure it every time I power it up? I have the latest and greatest Fieldpoint explorer and am using the FP-1000 Network Interface.
(4,621 Views)
Scott,
Go into FieldPoint Explorer, right click on the FP-1000 and choose Edit This Device. Uncheck the box that says Factory Configuration. Your module will then power up using your settings rather than the factory defaults. Please note that your settings are still in the network module, just not being used. You will not have to reconfigure the FP-TC-120 after unchecking the box. Just cycle the power and the module will power up with the Temperature range rather than the voltage range selected.
Aaron
LabVIEW Champion, CLA, CPI
(4,621 Views)
