02-19-2013 03:32 PM
I NEED TO HAVE 10 DIFFERENTIAL AND 8 SINGLE ENDED INPUTS, CAN I USE A NI 9205 IN A MIXED MODE OR DO I HAVE TO USE TWO SEPARATE INPUT MODULES?
02-20-2013
09:58 AM
- last edited on
09-26-2025
08:42 AM
by
Content Cleaner
Hi Charles3
The NI 9205 is a 32-channel single-ended/16-channel differential analog input module, what this means is that you can have 32-channel single-ended or 16-channel differential or some combination if you need 10 -channel differential you will have 12 -channel single-ended left to use. Keep in mind the differential pairs in order to use the other channels left.
Regards
Esteban R.
