FieldPoint Family
NI TPC 2106- supported CF cards
I would like to know if there is a documented list of supported CF cards for the NI TPC 2106. The SanDisk Extreme IV 4.0GB CF card I have was determined to cause conflicts with my TPC. So all I need to know is what CF cards I can use.
Thanks in advance.
(7,138 Views)
Hi vtme2007,
The CF card used is determined by the OS used with the Touch Panel. Since 2016 and till 2106, the OS used is Windows CE 5.0 and above. Microsoft maintains a list of supported hardware at this link. Hope this helps.
Ipshita C.
(7,116 Views)
@IP**bleep**a_C wrote:
Hi vtme2007,
Ip**bleep**a C.
I have the same question. I found the link that you posted, but it is getting tough to buy new cards that are supported and our company does not allow us to buy on Ebay. I was wondering whether there is an updated list or a firmware update available, so that newer cards can be used with the 2106T.
Isabel
(6,370 Views)
Hi Isabel,
As far as I understand, that is the most up-to-date list of supported cards.  Was there something in particular that you were looking at using?
Jared S.
Applications Engineering
(6,352 Views)
