FieldPoint Family
NIDAQ and Coriolis Flow Meter
Hey,
Can someone help me... I need to hook up a Coriolis Flow Meter with the Transmitter IFT9701 to the NI-DAQ - FP1000 but I can't find the wiring diagram.
There are just three wires coming out of the transmitter (red, black and plain) and gives an output of 19.8 volts on a multimeter.
Also, If you have any VIs or know where they are to find the flow rate measured my the flow meter, kindly send me the link or the file to saravarad@gmail.com
Thanks in advance!!
Have a great day!
Saranathan
(6,522 Views)
Here is a link to instruction manual for IFT9701 transmitter.  http://fmtech.kr/fmtechco/pdf/MANUAL,IFT9701%20W-LDO.pdf?PHPSESSID=fe0ca2f3d75f1164ff45858278af6554
This transmitter has two outputs.  A 4-20mA current loop and a pulse train.
You mentioned that you have a Field Point model FP-1000 network module, but you didn't say which I/O modules you have.
(6,520 Views)
