FieldPoint Family
Need an opinion about FieldPoint RT Communication
The system I am controlling with compact Field Point consists of the chamber (initially filled with air), turbo pump (below), valve on the right of turbo pump, scroll pump below.
The I/O boards installed in FP are : DO-403, RLY-421, DI-301, DI-330.
I use:
- DO-403 to close and open the valve
- RLY-421 to start/stop turbo pump
- DI-301 to read the signal from multi-gauge (high/low) for 3 set points
- DI-330 to read signal from turbo pump (high/low) that tells me if the pump is in starting/normal operation
The process starts by turning the Scroll pump On and when the pressure in the pipe between turbo pump and scroll pump drops below setpoint 1 the Chamber2.vi will open the valve. The scroll contin
ues to pump the air out and when the pressure drops below set point 2 I start the turbo pump. Now both pumps are pumping the air out together and the pressure will start to decrease rapidly.
The Chamber2.vi is to automize the process of pumping the air put for this system.
I used RT Comm. Wizard and it built three VIs for me.
You can choose to do the same I believe and see what they look like.
I have few things to clear out:
-How does the VI look like from the Real Time point of view? Are there any bigger problems in a way I built it?
-My goal is to build stand-alone application that will be downloaded to FieldPoint. What would be the next step for me to do after I have made a NP VI, TC VI and Host VI? DO I download only Normal Prior. VI to the FP?
-One problem I had with RT Comm. Wizard is that the indicators: valve, pipe and scroll pump are not shown in the list of controls/indicators that you can select to be replaced with RT FIFO. Why is that?
Any suggestions, inputs
, critics will be greatly appreciated.
Pedja
one more thing...I have tried to build library with main VI and all subVIs together so that I can attach and post one single file only but I had some problems.
Can you instruct me on how to do this?
(3,249 Views)
Coop,
Please see the following discussion forum thread regarding your question:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000043E20000&UCATEGORY_0=_50_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=Coop&USEARCHCONTEXT_QUESTION_S=0
Ames
Application Engineering
(3,249 Views)
