FieldPoint Family
Need to reinstall Fieldpoint 5.0
I'm new to Fieldpoint, and in getting drivers installed I managed to install 5.0 and Fieldpoint Explorer 3.something.  Anyway, I found out that won't work, so I uninstalled Fieldpoint Explorer, and now my Fieldpoint 5.0 VI's are missing.  When I try to install 5.0 again, it says nothing needs to be updated.  I'm running Labview 8.0 right now, and will hopefully be on 8.20 by the end of the month.  will the 5.0.1 install work with 8.0 as well?  How would I uninstall and reinstall 5.0?  Thanks.
(3,425 Views)
wdkng_24:
You must of had a pretty old version of FieldPoint present on your system if you had FieldPoint 5.0 AND FieldPoint Explorer on your computer.  I would suggest at this point uninstalling FieldPoint 5.0, and reinstalling it again.  You can do this by going to Add Remove Programs from your Control Panel in Windows.
Just so you know, you no longer need FieldPoint Explorer.  If it is installed on your system from an older install, I would just ignore it and not use it - instead use Measurement and Automation Explorer to configure your FieldPoint hardware.
To answer your other question: Yes, FieldPoint 5.0.1 will work with LabVIEW 8.0 and LabVIEW 8.20.
-Tommy
(3,417 Views)
