FieldPoint Family
NetworkVariableDataSource.Bindings[VariableName].GetValue() leaks memory
Dear Sir,
We are using Measurement Studio 8.5 for Visual Studio 2005. Our application reads 105 Netwrok Variables in every seconds. It does the work done through NetworkVariableDataSource.Bindings[VariableName].GetValue(). So far we have tested and determined that the GetValue() methods leaks some memory and every seconds the memory consumption by the application goes up. How can we solve this problem? We are using c# lannguage.We need argent solution.
Mamunur Rashid,
TechnoVista Limited
Message 1 of 22
(10,146 Views)
public string readBufferedNetworkVariable()
            // validate variable name and location
            if (string.IsNullOrEmpty(VariableLocation) || string.IsNullOrEmpty(VariableName))
                throw new Exception("Variable Location and or Variable Name can not be Null");
            else
                if (VariableDataSource == null)
                    configureBufferedDataSource();
                try
                    string val;
                    val = VariableDataSource.Bindings[VariableName].GetValue().ToString();
                    return val;
                catch (ArgumentException)
                    // binding item does not exist
                    configureBufferedVariableBinding();
                    try
                        string val = VariableDataSource.Bindings[VariableName].GetValue().ToString();
                        return val;
                    catch (InvalidOperationException IOex)
                        Utility.SaveErrorLog("NINetworkVariableHelper", "readBufferedNetworkVariable", "VariableLocation:" + VariableLocation + " VariableName: " + VariableName + Environment.NewLine + IOex.StackTrace + Environment.NewLine + "Message: " + IOex.Message);
                        return "n/a";
                     return "n/a";
                catch (Exception ex)
                    // just in case
                    Utility.SaveErrorLog("NINetworkVariableHelper", "readBufferedNetworkVariable", "VariableLocation:" + VariableLocation + " VariableName: " + VariableName + Environment.NewLine + ex.StackTrace + Environment.NewLine + "Message: " + ex.Message);
                     return "n/a";
I have to call the method 105 times in every second.
Message Edited by Mamun on 07-20-2009 10:37 PM
Message 2 of 22
(10,123 Views)
Mamun,
Thanks for the code.  I am going to try and set up a similar system and do some testing to see if I experience the same behavior.  Can you give me some more information about your system and about the memory consumption you are seeing? (RAM, hard drive space, amount of RAM used by the program after 30s, 1 min, etc)
Eric B.
Message 3 of 22
(10,109 Views)
Dear Eric B.,
Some Information about our system:
RAM:  2GB
Hard Drive: C: 40GB 😧 214GB E: 210GB
Memory Consumption by 8 browsers simulatiously:
10  mins : 126,608 kb
30  mins : 167,196 kb
1 hour    :  236,440 kb
2 hours   : 375,188 kb
2.5 hours : 421,244 kb
6/7 hours : ~(600,000-700,000) kb and at that point some re-adjustment of memory consumption occur. For example, if it is 650,660 kb in next second it is 645,312 kb.
Now I would like to explain  the architecture of our application.
1) ASPX Page: We have got an .aspx page which includes an ajax timer. The timer refreshes the page in every second where around 105 user controls (5 types of user control) are being refreshed with new value. I will provide you the 'Tick' method which is accounts for  refresing the user controls.
2) User Controls:  a) NINetworkVariableButton.ascx : It inherits ASP:Button
                              b) NINetworkVariableLabel.ascx : It inherits ASP:Label
                              c) NINetworkVariableRadioButton.ascx :  It inherits ASP:RadioButtonList
                              d) NINetworkVariableReadOnlyTextBox.ascx :  It inherits ASP:TextBox
                              e) NINetworkVariableTextBox.ascx :  It inherits ASP:TextBox
All user controls  contain properties 1) VariableName 2) VariableLocation and a method 'readData()'. In  'readData()' it uses an instance of class 'NINetworkVariableHelper' and calls the method  'readBufferedNetworkVariable()' of that class.
I will provide 1 of user controls to you.
3)  Class 'NINetworkVariableHelper': Reading and Wrinting of data to the network variable are done through this class and the methods are  'readBufferedNetworkVariable()' and 'writeBufferedNetworkVariable()'. I am also going to provide the class.
Message 4 of 22
(10,098 Views)
 Dear Eric B.,
Following are some code segements
Some aspx code:
<td>
<asp:UpdatePanel ID="UpdatePanelDO_KV601A_KV601B" runat="server" UpdateMode="Conditional">
<ContentTemplate>
<uc3:NIButton ID="DO_KV601A_KV601B" runat="server" VariableName="DO_KV601A-KV601B"
Caption="KV601A-B"></uc3:NIButton>
</ContentTemplate>
<Triggers>
<asp:AsyncPostBackTrigger ControlID="Timer1" EventName="Tick"></asp:AsyncPostBackTrigger>
</Triggers>
</asp:UpdatePanel>
</td>
<td>
<asp:UpdatePanel ID="UpdatePanelAO_FC601" runat="server" UpdateMode="Conditional">
<ContentTemplate>
<uc2:NIText ID="AO_FC601" ToolTip="FC601" runat="server" VariableName="FC601"></uc2:NIText>
</ContentTemplate>
<%--<triggers>
</triggers>--%>
</asp:UpdatePanel>
</td>
<td>
<asp:UpdatePanel ID="UpdatePanel51" runat="server" UpdateMode="conditional">
<Triggers>
<asp:AsyncPostBackTrigger ControlID="Timer1" EventName="Tick" />
</Triggers>
<ContentTemplate>
<uc1:NIReadOnlyText ID="AI_FT601" VariableName="FT601" ToolTip="FT601" runat="server"
Enabled="false"></uc1:NIReadOnlyText>
slpm
</ContentTemplate>
</asp:UpdatePanel>
</td>
  Some code of Timer1_Tick of aspx.cs
protected void Timer1_Tick(object sender, EventArgs e)
refreshCustomControls(Page.Controls[0]);
protected void refreshCustomControls(Control control)
if (control is NINetworkVariableTextBox)
if (!txtActiveControlID.Text.Contains(control.ID))
// get the update panel that this user control lives in
// Control updatePnl = Page.FindControl(control.Parent.Parent.ID);
Control updatePnl = control.Parent.Parent;
NINetworkVariableTextBox tb = (NINetworkVariableTextBox)control;
string origValue = tb.Text;
// read the current data from the shared variable
tb.readData();
// tell this update panel to update
((UpdatePanel)updatePnl).Update(); //It is needed to remove yellow back color and update data and here no asychonous postback is used
else if (control is NINetworkVariableReadOnlyTextBox)
FormattingValueOfReadOnlyText(control);
else if (control is NINetworkVariableButton)
((NINetworkVariableButton)control).readData();
/* these controls are in asychonous update with timer so dont need to update panel update()*/
else if (control is NINetworkVariableRadioButton)
//if (control.ID != txtActiveControlID.Text)
((NINetworkVariableRadioButton)control).readData();
else if (control.ID == "controlgraph")
return;
else
foreach (Control child in control.Controls)
refreshCustomControls(child);
Message 5 of 22
(10,096 Views)
User Control NINetworkVariableTextBox.ascx:
using System;
using System.Data;
using System.Configuration;
using System.Collections;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.IO;
using System.Text;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using NationalInstruments.NetworkVariable.WebForms;
using EndeavorEngineering;
using System.ComponentModel;
public delegate void TextBoxWriteCompletedEventHandler(object sender);
public partial class NINetworkVariableTextBox : System.Web.UI.UserControl
NINetworkVariableHelper _NIHelper = new NINetworkVariableHelper();
//string _text = "";
string _width = "50px";
bool _readOnly = false;
bool _enabled = true;
bool _displayAsDouble = true;
string _skinID = "";
string _variableLocation = "";
public event TextBoxWriteCompletedEventHandler TextBoxWriteCompleted;
public string VariableName
get { return _NIHelper.VariableName; }
set { _NIHelper.VariableName = value; }
public string VariableLocation
get { return Session["variableLocation"].ToString(); }
set { Session["variableLocation"] = value; }
//get { return _variableLocation; }
//set { _variableLocation= value; }
public string Text
get { return TextBox1.Text; }
set { TextBox1.Text = value; }
public bool ReadOnly
get { return _readOnly; }
set { _readOnly = value; }
public string Width
get { return _width; }
set { _width = value; }
public bool Enabled
get { return _enabled; }
set { _enabled = value; }
public bool DisplayAsDouble
get { return _displayAsDouble; }
set { _displayAsDouble = value; }
public string ToolTip
get { return TextBox1.ToolTip; }
set { TextBox1.ToolTip = value; }
protected void Page_Load(object sender, EventArgs e)
if (!IsPostBack)
TextBox1.Width = Unit.Parse(Width);
TextBox1.ReadOnly = ReadOnly;
TextBox1.Enabled = Enabled;
TextBox1.ToolTip = VariableName;
if (!ReadOnly)
TextBox1.Attributes.Add("onfocus", "SetActiveControl('" + this.ID.ToString() + "',this);");
TextBox1.Attributes.Add("onkeypress", "return newEnterhandler(event)");
else
TextBox1.BackColor = System.Drawing.Color.Gainsboro;
readData();
public void readData()
_NIHelper.VariableDataSource = (NetworkVariableDataSource)Session["ds"];
_NIHelper.VariableLocation = VariableLocation;
string val = _NIHelper.readBufferedNetworkVariable();
if (DisplayAsDouble)
if (IsNumeric(val))
if (VariableName.Contains("Voltage") || VariableName.Contains("ET") || VariableName.Contains("CurrentDensity"))
// three digits of percision for voltage
TextBox1.Text = String.Format("{0:F3}", double.Parse(val));
else
TextBox1.Text = String.Format("{0:F}", double.Parse(val));
else
TextBox1.Text = val;
else
try
if ((Session["Role"].ToString() == "Test Engineer" || Session["Role"].ToString() == "Admin")
&& (Utility.GetCurrentState(Session["STSNumber"].ToString()) == Utility.OperationalState.MANUAL))
TextBox1.Enabled = true;
else
TextBox1.Enabled = false;
catch { }
Session["ds"] = _NIHelper.VariableDataSource;
public void writeData(string value)
_NIHelper.writeBufferedNetworkVariable(TextBox1.Text);
//raise event that the write finished
WriteCompleted();
protected void _NIHelper_NetworkVariableReadFailed(object sender, EventArgs e)
protected void _NIHelper_NetworkVariableWriteFailed(object sender, EventArgs e)
protected void WriteCompleted()
TextBoxWriteCompletedEventHandler RaiseTextBoxWriteCompleted = TextBoxWriteCompleted;
if (RaiseTextBoxWriteCompleted != null)
RaiseTextBoxWriteCompleted(this);
protected static bool IsNumeric(object Expression)
bool isNum;
double retNum;
isNum = Double.TryParse(Convert.ToString(Expression), System.Globalization.NumberStyles.Any, System.Globalization.NumberFormatInfo.InvariantInfo, out retNum);
return isNum;
protected override void Render(HtmlTextWriter writer)
StringBuilder sb = new StringBuilder();
StringWriter sw = new StringWriter(sb);
HtmlTextWriter hWriter = new HtmlTextWriter(sw);
base.Render(hWriter);
//Image led = _NIHelper.VariableQualityLED;
//led.RenderControl(hWriter);
// *** store to a string
string PageResult = sb.ToString();
writer.Write(PageResult);
Message 6 of 22
(10,095 Views)
public class NINetworkVariableHelper
NetworkVariableDataSource _nvDS;
NetworkVariableReader<object> _nvr;
NetworkVariableWriter<object> _nvw;
NetworkVariableData<object> _nvd;
string _variableName;
string _variableLocation;
string _variableQuality;
string _variableQualityText;
public event NetworkVariableWriteFailedEventHandler NetworkVariableWriteFailed;
public event NetworkVariableReadFailedEventHandler NetworkVariableReadFailed;
public NINetworkVariableHelper()
#region Properties
get
return _variableName.Substring(_variableName.IndexOf("_") + 1);
set
_variableName = value;
get
set
_variableLocation = value;
public NetworkVariableDataSource VariableDataSource
get
return _nvDS;
set
_nvDS = value;
#endregion
else
try
string val;
return val;
try
return val;
return "n/a";
return "n/a";
// just in case
return "n/a";
Message 7 of 22
(10,094 Views)
Hi Mamun,
Thank you again for the code, it was very helpful in trying to replicate the issue to see if I saw the same behavior.  I was able to create an ASPX page bound to 10 variables that called getValue 10 times per second and I did see some memory leakage.  I will be filing a bug report on this to the developers and we are looking to see if there is a workaround for your situation aside from just closing and reopening the browser periodically to release the memory.
Eric B.
Message 8 of 22
(10,071 Views)
Hi Eric B.,
Any update?
Mamun
Software Engineer
TechnoVista Limited
Message 9 of 22
(9,918 Views)
Mamun,
I filed a bug report with the developers shortly after my last post.  The bug ID for this report is 183378.  You can use this bug ID to look at the released list of fixed bugs every time Measurement Studio is released to see if the bug has been fixed.  The report was assigned to a developer and they are looking into a resolution, but I don't know much more than that.
Eric B.
Message 10 of 22
(9,900 Views)
