FieldPoint Family
New cFP-SG-140 Power LED Flashing
Hi ab_man,
Thanks for the information.  I will let you know what I find when I receive the module.
Just to verify, you RMA'd the module this morning, correct?
Ching P.
DAQ and Academic Hardware R&D
Message 11 of 23
(4,009 Views)
cphong,
I did RMA the unit in question and that number is 163461 if you want to intercept it
ab_man
Message 12 of 23
(4,003 Views)
Thanks ab_man,
I have placed an inspection hold on this module, and will get back to you as soon as I get the module.
Ching P.
Message 13 of 23
(3,999 Views)
Ching,
I wanted to let you know that I left power off of the chassis last night and when I powered it up this morning with the sg-140 in place (Slot 3) that the power light stabilized and the ready light came on. If I hot swap the unit the power light starts and keeps flashing. Once I discovered this I cycled power off for 3 minutes and powered up again. Power light still flashed. I then cycled power off for 30 minutes it works. I don't know what to do at this point . I already have an RMA on it and the mailroom is preparing to ship it back
ab_man
Message 14 of 23
(3,992 Views)
Hi ab_man,
Thanks for the update.  I'll keep this in mind when I get your module.
Ching P.
Message 15 of 23
(3,987 Views)
Hi ab_man,
Our RMA department received your module on Friday.  I will be picking it up tomorrow for testing.
Ching P.
Message 16 of 23
(3,936 Views)
Hi ab_man,
I was able to reproduce the issue.  RMA upgraded the module to the latest revision, and that seems to have fixed the problem.  I tested for a while after the upgrade, and was unable to reproduce the blinking Power LED.  The new module you received should be the latest revision, therefore should not have that issue.
Please let me know if you have any questions or concerns.
Ching P.
Message 17 of 23
(3,914 Views)
Was that an upgrade I could have performed?
ab_man
Message 18 of 23
(3,912 Views)
Hi ab_man,
No, this is not an upgrade you could have performed.
Please let me know if you have any other questions.
Ching P.
Message 19 of 23
(3,907 Views)
Thanks for all your help
ab_man
Message 20 of 23
(3,906 Views)
