FieldPoint Family
No display on front panel
We use one FP-1601, one TC-120, three AI-110, one DO-401, and one CTR-502 for our real-time data sampling systems. We found that the numbers and figures could not be shown (updated) on the front panel. But the Max was able to show all the correct measurements (Volts, Amps and Counts). Also, we found that the measurements from those modules can not be read by the code but the code can control the DO-401 very well.  So anybody tell me why and how to fix it? Is it an iak file problem? Thanks!
Fred
(5,989 Views)
Hi Fred,
The issue could be related to the iak file.  Are you using error handling and reporting to tell what the exact problem is?  Is this an executable or a VI?  It changes which iak file is loaded.  Can you create a new VI that uses the iak file from MAX and see if you are able to read values from the FieldPoint.
Justin Parker
Product Support Engineer
(5,962 Views)
