FieldPoint Family
OpcFieldpoint server With Other Vendors Hardware
Does anyone know if the NI OPC Fieldpoint OPC server will work with other TCP Modbus hardware? I may need to attach some non-Nat Inst network modules to a network of Compact Fieldpoint devices.
If so, how do I configure the network?
For info, the other hardware is Wago 750 series
TIA
Tony
(3,452 Views)
Hi Tony,
There are various KBs out there on accessing Modbus hardware. Firstly, you will need to obtain the OPC driver from your provider for your Wago network module. Check out these KBs for more information:
Modbus Library for LabVIEW (please note there are different files for LV 7.1 and 8.2, if you have 8.0 then there is a small quirk)
http://sine.ni.com/devzone/cda/epd/p/id/4756
Do LabVIEW and LabVIEW Real-Time Support Modbus?
http://digital.ni.com/public.nsf/websearch/2CD034F223C650E9862569570041995C?OpenDocument
Why Is Modbus Not Listed As an I/O Server in My LabVIEW Project?
http://digital.ni.com/public.nsf/websearch/69BC633270DA5CD68625724400058597?OpenDocument
Modbus Register Mapping in LabVIEW 8.x
http://digital.ni.com/public.nsf/websearch/64D9902E8B9AE4AF8625712D0076B463?OpenDocument
Let me know if you have any other questions.
Regards
Way S.
NI UK Applications Engineer
(3,441 Views)
