FieldPoint Family
PH_EXEC_8.5.1__log.txt
I am running an application on a cfp-2120. The application has an embedded remote panel via the cfp web server.  I've noticed that the following error log is created, in the temp dir, when I use the panel. My guess is that the error is caused by a vi server call. Can anyone give me some insight into what this error means and what causes it?
______________________________________
#Date: Fri, Apr 25, 2008 8:24:51 PM
#OSName: PharLap
#OSVers: 13.0
#AppName: PH_EXEC
#Version: 8.5.1
#AppKind: AppLib
LVRT.DLL load address: 0x002F2000
4/25/08 8:26:57.671 PM
C:\dev\jupiter_851\source\server\TCPServerPacket.cpp(224) : DWarnInternal: ~TCPServerParamPacket : didn't read correct amount. offset=20, size=231
0x00440857 - <unknown> + 0
0x00440F24 - <unknown> + 0
0x00415B59 - <unknown> + 0
0x0041B94C - <unknown> + 0
0x004186E8 - <unknown> + 0
0x0041A018 - <unknown> + 0
0x0041CC56 - <unknown> + 0
0x0041CFB1 - <unknown> + 0
0x0041D020 - <unknown> + 0
0x0041B435 - <unknown> + 0
0x0041C99B - <unknown> + 0
0x002F7ED3 - <unknown> + 0
0x002F9773 - <unknown> + 0
0x0030D12F - <unknown> + 0
0x0030D5D8 - <unknown> + 0
0x002F5249 - <unknown> + 0
0x00309A6B - <unknown> + 0
0x00340A2E - <unknown> + 0
0x00340CD9 - <unknown> + 0
0x002EB013 - <unknown> + 0
0x001092DA - <unknown> + 0
0x0019D545 - <unknown> + 0
0x00035FCF - <unknown> + 0
0x0000CA79 - <unknown> + 0
0x0000CC61 - <unknown> + 0
0x0002BD39 - <unknown> + 0
0xFB3C6683 - <unknown> + 0
(6,195 Views)
un-yah,
This appears to be a bug related to VI Server, as you said.
Since it is only a warning, you can probably safely ignore it.
In the future, you can also report these errors directly to National Instruments using the prompt that LabVIEW gives you the first time you start it after an error was experienced.
This was reported to R&D (#
58398) for further investigation. Thanks for the feedback!
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
(6,175 Views)
