FieldPoint Family
PS-4 Dimensional Drawings
Hi
There appears to be two variations of the PS-4 power supply for Fieldpoint. One is the FP-PS-4 with PN: 323179A-01 and the other is the PS-4 with PN: 778586-90.
I know the FP-PS-4 looks like a modular Fieldpoint module but I cannot find any information on the PS-4. I'm after a dimensional drawing so I can work out where it will fit within my cabinet.
Much appreciated.
Kurt Friday
www.sciware.com.au
(3,942 Views)
Kurt,
The PS-4 is a DC power supply, that can be used to supply power for FieldPoint banks. It’s not an actual FieldPoint module at all, it is completely separate from the FieldPoint lineup, but can be used to power a FieldPoint bank. If you need dimensional specs for the PS-4 please directly contact National Instruments Technical Support.
-GDE
(3,939 Views)
Kurt,
The FP PS-4 and PS-4 are one and the same item. The 778586-90 part number is the orderable kit which includes the 323179A-01 PS-4 power supply. The PS-4 is a power supply in the FieldPoint form factor. You can use the dxf drawing of a FieldPoint Network module as it will have the same dimensions, with slightly different IO locations. The dimensional drawings are here:
https://www.ni.com/en/support/documentation/dimensional-drawings.html
Aaron
LabVIEW Champion, CLA, CPI
(3,931 Views)
Thanks Aron, that has cleared up the ambiguity.
Message Edited by SciWare on 06-07-2006 07:50 PM
Kurt Friday
www.sciware.com.au
(3,926 Views)
