FieldPoint Family
Problem NI VISION
i deleted all data from my CVS and the vision makes a reboot. After this reboot the IP-adress was set to 0.0.0.0 and the system was visible on the Measurement & Automation Explorer. Than i have changed the IP-Adress. The system reboots but it was not visible on the M&A Explorer.
The Status LED is blinking two times and in the user-manual is written, that i must upgrade the firmware. But The problem is, were i can found it and how i  upgrade the firmware.
(5,969 Views)
please try following: Start your CVS in save mode. Then go into MAX choose your CVS, make a rightclick and choose format. Then install Software from MAX new.
Rebecca Fox
(5,951 Views)
