FieldPoint Family
Problem in FP-1601
Hello every body
FP-1601
AI-100
AO-200
Max 4.4
LabVIEW 8.5.1
Windows Vista
I’m connect the controller 1601 to PC by using cross cable, the MAX show the controller  under remote system but if connect any module to the controller then disconnect between the controller and PC,  MAX and LabVIEW don’t show FP-1601.
How to solve this problem?
Thanks every body
Message 1 of 10
(8,658 Views)
Hi!
   You'd like MAX and LV to see FP module even with cable disconnected? It's not clear...
graziano
Message 2 of 10
(8,651 Views)
Thank for send to me.
 I know ,way Disconnect?
Regards
Message 3 of 10
(8,648 Views)
Hi!
   Once again, I don't understand.
   You loose connection AFTER CONNECTING A MODULE to FP-1601, or AFTER DISCONNECTING NETWORK CABLE?
   If it's the first case, how do you connect module to cFP-1601? you connect a Terminal Base while module is running? Or you just plug a module into an existing Terminal Base already connected toFP-1601?
   Please clearify, the problem, here, is with LANGUAGE! (almost for me...)
graziano
Message 4 of 10
(8,646 Views)
Hi
I'm sorry.
Just plug a module into an existing Terminal Base already connected to FP-1601.
Message 5 of 10
(8,644 Views)
Hi!
   Plugging a module into an existing TB should not be a problem.  What if you power on all system with module inserted? In this case, can MAX see the FP-1601?
   Another possibility can be that you have a wrong connection on the TB, some wrong Ground connection, or an electric problem like this.
   Let me know!
graziano
Message 6 of 10
(8,642 Views)
Hi
The MAX see the FP-1601 if don't connect the modules if connect the module the Power LED and Ready LED on but MAX disconnect.
Reagards
Message 7 of 10
(8,639 Views)
Hi!
   From what you say, everything should be fine (I checked also User Manual, page 4-3), I don't know why you have this behavior.
   The only ideas I have, are the FP-1601 is not working properly or some I/O wiring disturbs working conditions... anyway, I'd look for NI assistance.
graziano
Message Edited by Graziano on 10-27-2008 08:55 AM
Message 8 of 10
(8,635 Views)
Hi
I don't connect any I/O in the modules.
Message 9 of 10
(8,630 Views)
Hi Spring,
Have you done a manual reset of the cFP-1601 with the modules already attached? Or do you add the modules, and the cFP-1601 is removed from MAX without a reset? I recommend trying the first option if you haven't already. Some other ideas for trouble-shooting problems with this network module can be found here: http://zone.ni.com/devzone/cda/tut/p/id/4368
Product Support Engineer
Message 10 of 10
(8,605 Views)
