FieldPoint Family
Programatically determine presence of strain gauge?
Is it possible to determine programatically whether a strain gauge is actually connected to an xFP-SG-140 module? Suggestions for how to do it? Thanks.
Matt
(3,531 Views)
FieldPoint does not have a programmatic way to detect open strain gauges built in to the hardware or driver. You may want to consider implementing some control in your software that monitors the values read on your analog input channels. If you begin to receive readings that seem impossible if a strain gauge was attached to the module, then you could assume an open connection.
Jared A
(3,531 Views)
Thanks. That is what I was hoping to avoid. Looks like if I set the noise filter to 240Hz I get enough noise to distinguish between sensor present or not. Not a great way to do it but should be ok. Appreciate the input.
Matt
(3,531 Views)
Hello Matt,
Jared is out teaching, but if you have any futher questions please don't hesitate in contacting us back.
LA
(3,531 Views)
